  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ive never had a zit problem ever - but last week i have - i think its been either stress or my foundation (ive since thrown away the foundation)
Peeling nose - just some good quality mosturiser - maybe some nivea for men - i know it sounds pussie but just use it - will help.
yes i was burnt too but thats because everywhere i mved the shade would move away from me!!!
Hmmm mustnt of been introduced 33spec2 (although i was seriously hung over and didnt have the brain power to talk to a chimp) just dont remember u!
yeah im a shy girl when im hung over and majorly sick - cmon i had to be i let joe drive haha the first thing my parent said when i told them Joe drove my car they go "well u didnt let andy drive your car (ex)" haha so for anyone else other than me drive car - im really crook! But i must give my compliments to joe he did a good job!!
Hahah Men love moisturiser they just have a problem admitting the fact i tell ya i bought "special" moisturiser that cost me like $38 dollars my ex used more than me!! i was annoyed and my shampoo! hahaha
hmmm joe really feeling like an alcholoic now - i think its just hit me - room spinning a bit but its all good.
You dont want to know how long it took me to edit that!!
Yeah im a post whore haha - one of us girls had to become one and keep you boys in line!! and since im the only single one amongst them with the time on my hands i guess it was me that was delegated!!
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
