  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Micko, It shouldn't be too bad if you know what your doing, but your lucky your car will be cold, mine will be boiling by the time I get it to you.
I'm going home, over at the folks, so I'll be off air for 30mins, don't miss me too much:p
See'ya:burnout:
Originally posted by Micko
you got a filter removal tool paul?
Micko,
Unless you have a very thin one or the 3 pronged one like I have , forget it.
Get pwptf to come past on the way thru and pick up the 3 prong one.
Ya got a 3/8 drive ratchet ??
And you are correct , it will piss oil over the front diff which will dribble for about 2 days.
Damn GTR's. Hehehe
Cheers
Ken
And you are correct Loz , it is friggin hot with tomorrow being hotter.
Will be in front of aircond and TV from 7.30 to 2pm tomorrow though.
Cheers
not getting the manifold done at this rate
ken
you doing the manifold today ken?
i wish i knew cos i would like to have seen how it comes apart for myself...spose it would be much harder with someone standing there asking 10000 questions:)
Nope , walked outside this morning into the garage, decided I didn't need a 8 hr sauna so went back in and clocked up brownie points.
You know , making salads , cooking and washing up for the bbq.
Us married men have got it hard compared to the singles out there.:bahaha:
Cheers
Ken
mmm had two hour nanna nap - bad dream included! Think it may be beach for my tommorrow - then again to get to beach have to drive 40mins in unaircon car on second thoughts may just stay home in heated pool n spa with cold drinks close by.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
