  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I'm back from my afternoon on the river .
Coolcruise in the Bayliner 23 from Guildford to Matilda bay for a picnic tea and a few beers , then back to guildford , on the trailer and home.
As I was sitting out the front, cool breeze blowing and skimming across the Melville waters millpond is was thinking
* I wonder what the plebs are doing *
Now I know , breaking sumplugs , back windows and getting hot.
Hehehehe
Cheers
Ken
mostly stuck in garage - its quick but handles like a dinosaur - a dangerous combination! Its dragged a skyline and won and i reckon that my skyline is probably slower but my skyline is a lot safer to handle. Nearly ended up being my coffin a couple of times - incuding once loosing control and almost becoming truck food!
mmm yeah a lot rarer than the 180 - i had a choice between the 180 and my Z31 - and i just fell in love with my Z31 and that was it! But its rare to see ones in that condition and ive only seen one other black one around - the guy that owned it bought it out from hong kong in 95 owned it since new - he now drives a line that looks a lot like mine but can shite all over it with the amount of mods he's done (he's about 60 its really funny lil boy at heart me thinks) he was there when i went to pick my line up!
Hes done a few useless ricey things to that ZX such it beeps when the break pads are low haha
Originally posted by GTS-t VSPEC
Ken,
Your a bastard!
Scoring more brownie points with the Mrs?
I feel sorry for Micko. just when things were looking up. Do you have a rear window for him?
See'ya:burnout:
Stuff the brownie points , I wanted to do it and she was happy as well ( double bonus )
wtf did you do to Mickos sump plug ??
Cheers
Ken
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
