  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
*Ken reliving past glories*:bahaha:
Swedish skid car? a Volvo?
See'ya:burnout:
Take a look in the garage at the next MC day and you will see what I mean.
Trust me , teaching the general population about skid control , recognition and recovery is not easy.
The amount of people who react about 2 secs behind the car is scarey:mad:
Cheers
Ken
Originally posted by bully
Ken i used the one at Puckapunyal in victoria I was A Navy driving istructor there -- i think we had the firsts set in the country
That would have been the ones with landrovers on them.
I think you got them thru NZ
Cheers
Ken
Bully,
Thanks for the lesson in old cars. You old guys are good for something.
See'ya:burnout:
ahh youth and stupidity ......
Goes hand in hand . Little one , listen for there is much to learn.....
Cheers
Ken
yer we also set them o up with some Falcons on them
we had Nissan Pulsar N14's on ours and moved to toyota Camrys ( V6 ).
Used to love doing the reverse flick into h/brake into reverse flick after the students had gone.
Any one who reckons you can't opposite lock a front wheel drive has NOT been in one of these things. Hehehehe
Cheers
Ken
Ken -- do you know Geoff Branch??
No but I believe a couple of guys came from the Army over there with skid car experience and are working for DTEC
John Willmot is one I think
Cheers
Ken
Cheers
Ken
i think i saw a video of that set up with the camrys once when we were look into contracting out driver training for the services
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
