  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
I know alot of people who want to kick his ass, but I don't have the budget to do that. I just want to take my fully modded street car and race it.
See'ya:burnout:
well forget getting more power.
Go for the biggest badass son of a bitch they stop , mother fu**er brakes on it and strip the car.
ANY road car using road type brake rotors and calipers will not last 6 hard laps around there.
If it does , yo ain't trying hard enough boy !
Cheers
Ken
Ken,
If you were her father, then I bet she thanks god she looks like her mother:p
See'ya:burnout:
well thank god I'm not her Father cos it would be incestous thoughts not just dirty old man thoughts.
Hehehe
Cheers
Ken
ps Just kidding loz , really . Would treat you like a daughter, honest.:P
I have the option of buying R32 GTR brakes, don't know if they are worth it.
See'ya:burnout:
Ahh you have 4 spot 296x28 mm rotors on the front of yours.
R32 gtr have 4 spot 296 x30 mm rotors on the front.
The gain is ?.......
Cheers
Ken
I have seen a set of 8pot Brembo brakes, I think they would do the trick, tied with some 360mm disks:p
See'ya:burnout:
NOW ya talking.
Trouble is can only go up 1 inch on std size wheel so 360mm are a bit tight.
But you are getting the idea. must get the ones with no dust seals or will set fire to them ( I did )
Cheers
Ken
Cheers
Ken
2mm paul only wishes he could get an increase like that where he needs it.
:P hehehe
They are cross-drilled? So not much point. I'll have to buy some decent 6pot AP's, don't want to sell me yours?
See'ya:burnout:
crossdrilled for racing is crap.
Stress heat cracks start from the holes and run to the outside very quickly.
In fact I don't know why they cross drill discs?
Cheers
Ken
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
