  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
I know alot of people who want to kick his ass, but I don't have the budget to do that. I just want to take my fully modded street car and race it.
See'ya:burnout:
well forget getting more power.
Go for the biggest badass son of a bitch they stop , mother fu**er brakes on it and strip the car.
ANY road car using road type brake rotors and calipers will not last 6 hard laps around there.
If it does , yo ain't trying hard enough boy !
Cheers
Ken
Ken,
If you were her father, then I bet she thanks god she looks like her mother:p
See'ya:burnout:
well thank god I'm not her Father cos it would be incestous thoughts not just dirty old man thoughts.
Hehehe
Cheers
Ken
ps Just kidding loz , really . Would treat you like a daughter, honest.:P
I have the option of buying R32 GTR brakes, don't know if they are worth it.
See'ya:burnout:
Ahh you have 4 spot 296x28 mm rotors on the front of yours.
R32 gtr have 4 spot 296 x30 mm rotors on the front.
The gain is ?.......
Cheers
Ken
I have seen a set of 8pot Brembo brakes, I think they would do the trick, tied with some 360mm disks:p
See'ya:burnout:
NOW ya talking.
Trouble is can only go up 1 inch on std size wheel so 360mm are a bit tight.
But you are getting the idea. must get the ones with no dust seals or will set fire to them ( I did )
Cheers
Ken
Cheers
Ken
2mm paul only wishes he could get an increase like that where he needs it.
:P hehehe
They are cross-drilled? So not much point. I'll have to buy some decent 6pot AP's, don't want to sell me yours?
See'ya:burnout:
crossdrilled for racing is crap.
Stress heat cracks start from the holes and run to the outside very quickly.
In fact I don't know why they cross drill discs?
Cheers
Ken
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
