  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
Yeah, i heard cross-drilled sucks.
You'll have to show me how to take off my calipers and change brake-pads next time I'm over. Couldn't figure it out the other day.
See'ya:burnout:
Don't take calipers off.
Pull slide pins out after taking retainer wire off , push pistons back with 2 screwdrivers and drop pads in.
Cheers
Ken
Bully,
No 2mm isn't worth the effort, and I think the ventillation is the primary cooling feature.
Ken,
Your on mIRC aswell?
See'ya:burnout:
yep , when some one else bothers to come on
Cheers
Ken
Originally posted by bully
what are these green pads i hear about?
EBC pads.
hmm this is GTRKEN posting here , not gtrken ( so I am not liable for prosecution )
They are crap.
Cheers
been there done that
Ken
Ken,
Will you be bringing in any GTR's under the 15 year rule?
See'ya:burnout:
no , not enough margin and I doubt you will find any good ones cheap.
People want a fast GTR but are too scared to buy a modified one.
Go figure ?
Cheers
Ken
yes I have to admit that mirc promotes quick one line comments or answers cos of the speed.
Can also be tricky to follow a particular thread of conversation thru the numerous topics being discussed.
Cheers
Ken
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
