  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
Yeah, i heard cross-drilled sucks.
You'll have to show me how to take off my calipers and change brake-pads next time I'm over. Couldn't figure it out the other day.
See'ya:burnout:
Don't take calipers off.
Pull slide pins out after taking retainer wire off , push pistons back with 2 screwdrivers and drop pads in.
Cheers
Ken
Bully,
No 2mm isn't worth the effort, and I think the ventillation is the primary cooling feature.
Ken,
Your on mIRC aswell?
See'ya:burnout:
yep , when some one else bothers to come on
Cheers
Ken
Originally posted by bully
what are these green pads i hear about?
EBC pads.
hmm this is GTRKEN posting here , not gtrken ( so I am not liable for prosecution )
They are crap.
Cheers
been there done that
Ken
Ken,
Will you be bringing in any GTR's under the 15 year rule?
See'ya:burnout:
no , not enough margin and I doubt you will find any good ones cheap.
People want a fast GTR but are too scared to buy a modified one.
Go figure ?
Cheers
Ken
yes I have to admit that mirc promotes quick one line comments or answers cos of the speed.
Can also be tricky to follow a particular thread of conversation thru the numerous topics being discussed.
Cheers
Ken
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
