  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
EPOCH,
Yes, next to a brothel, but even I am not that desparate, that's money I could spend on mods:p
Ken,
What pads do you recommend? *speaking to GTRKEN*
See'ya:burnout:
best roadbased pad ( ie good cold bite , kind to discs , reasonable wear , no or little fade ) would have to be Pagid rs4-2's ( blue ones ).
I have not tried too many but the pagids are good for me.
Ferodo 2500 or 3000 are also supposed to work.
Ultimately you get exactly what you pay for.
price for pagids are bout $400 an end.
Cheers
Ken
If I buy one, then I want a fully modded one, prefer with roll cage etc. Sometime next year i hope.
See'ya:burnout:
Cage will not be legal over here and watch the mods. Depending on what you want to do ( wanners ,ses , mc) some of the mods may not be legal.
I can get them but suppose Danny or Ray will help you there.
Cheers
Ken
At $400 I think I'll stick with cheapies:p
See'ya:burnout:
ahh well , thats why a more dedicated person will beat you.
Motor racing is hell expensive at every level and there will always be someone who will commit to the best.
Wanners is 75% car , 25% driver . A bad driver can win in a good car but the opposite will never happen.
Cheers
Ken
Morning Troy,
Vibration can be due to a unblanced flywheel, or the fact that the harmonic balancer needs to be adjusted for the lightened flywheel.
Bunny hopping is usually due to the clutch's pucks gripping and then slipping.
See'ya:burnout:
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
