  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
oh a good memory the multimedia students
god there were some honies in that lot.
one of em was caught bonking the lecturer to get a pass mark
naughty naughty
Hmmm I never heard of that one!!!!!
But ohhh yeah there were some very very nice looking ladies doing that course.... many of us on several occasions came very close to swapping courses!!!! :P
so u work near langtrees paul?
u should do lunch at the broken hill hotel on thursday from 12-2 hehe
aghh the broken hill - used to get molested if i even tried to walk past there to get to the bank when i worked at skippers haha. dodgy lot.
Trust you to know when the topless barmaids n strippers are on troy :P
Yeah I know that lecturer very very well.... What we couldnt work out though is she was quite often in that little building across the road in the public carpark next to the Tafe... we never could work out what the deal was with her!!!
Yeah that sounds about right..... Those were the days.... I swear we must of played cards about 2 hours each day back then.... It was cool. Luckily I am one of those people that the information just soked in without a great deal of attention/effort :P
Hmm not a bad effort..... I would like to go and get another certification but the costs and my apparent lack of motivation are stopping me so far.... Perhaps a Cisco ( which can now be done at TAFE ) or a Novell certification... both of which we use at work... I don't know what sort of coverage Novell has in the marketplace these days but its what I use daily at work so I figure that would be the most usefull to me...
My career has gone off on a tangent though .... I did the computer systems diploma so 99% of my training is in computers which is where I started in my job.... then after some redundancies I also inherited the RF paging networks of WA, now after further redundancies and restructures I need to support the Telecommunications 3G network we are building!!!! Most of which I have had no training in and no nothing about!!!!
Interesting times ahead :P
say hi back to two40 -little mobile phone fiend kept me amused at work yesterday - that first message he sent me i thought it was my ex with a new number - its like the stuff he sends me. crappy poems and weird weird things with double meanings. haha
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
