  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah i reckon we can pull it off easy enough... i think Adam doesn't trust us though, he still thinks we dropped a nut in his intake.
but i'll need someone to help me put the head back on, cause i'm no good at setting up cams properly. I've only done it on little ford 1.5 SOHC's before.
Bugger.. i doubt i'll have my car back together in time anyway, might just have to sit it out.
Yeah Adam's has got hyd/lifters.. we'll just need someone who can dial in the cams right, but the more hands the better..
that way we've got more people to share the blame when the next problem happens.
the new turbo bolts up perfectly except at the compressor intake and compressor output. I have to make custom mounts for those and grind a little out of the left engine mount. it a couple of "slack" days worth of work.
Yeah thats what i was thinking, we'll take it all apart, get someone to fix the valve, put it all back togther and get someone like Ray to dial in the cams, and give him a carton or two for his help.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
