  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah i reckon we can pull it off easy enough... i think Adam doesn't trust us though, he still thinks we dropped a nut in his intake.
but i'll need someone to help me put the head back on, cause i'm no good at setting up cams properly. I've only done it on little ford 1.5 SOHC's before.
Bugger.. i doubt i'll have my car back together in time anyway, might just have to sit it out.
Yeah Adam's has got hyd/lifters.. we'll just need someone who can dial in the cams right, but the more hands the better..
that way we've got more people to share the blame when the next problem happens.
the new turbo bolts up perfectly except at the compressor intake and compressor output. I have to make custom mounts for those and grind a little out of the left engine mount. it a couple of "slack" days worth of work.
Yeah thats what i was thinking, we'll take it all apart, get someone to fix the valve, put it all back togther and get someone like Ray to dial in the cams, and give him a carton or two for his help.
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
