  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
ah is not better, did you see her tonight? I'd rather root a boy:p
See'ya:burnout:
WHAT THAAAAAAAAAA!!!!! :D:bahaha:
Ewwwww.
Well i guess u finally came out and admitted it:)
must admit i wasnt gonna read back. but that made it all worth it
Psiker
this job looks alright could get me into the area i want Events/Public relations.
Got to organise morning tea etc for officials from india. Order some papadums - curry they'll be right hehe.
Anyway sometime gotta ring around and get quotes for catering.
Hows everyone this morning - miss me last night?
yeah theres always someone from a different country coming n going here. We have this room called the "bad taste room" where we put all their gifts hahaha I guess they have one too - we give them gifts
yeah its a little like that - heres your koala holding aussie flag - thankyou for twisted piece of metal (lets hope we dont get any visitors from Iraq - pressie could be a bomb haha)
Should give them a card 'Lets Bee friends' ahh gotta love the simpsons.
So what were you guys watching last night that led to the above conversation?
well gentleman ive got to go pick up stuff from the tourism commission and been told i can go play in town for a little while if i wish "ahhh working for the govt" so i'll catch yall later.
*kiss* Paul
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
