  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey Kym... Now Paul's gone we can make our moves :P
I just have a weekly report to write.... everything else gets done when it gets done...
Geeez is anyone going to be racing this week.... I thought being such a big event more people would want to race..... I want to race but it sure would be a hell of a night to start... I don't want to make an ass of myself in front of that many people...
Thats it though... I am talking about Drag Wars this saturday.... it looks like most people are only going to be watching... And as I said I havent been before and the last thing I want to do is screw it up in front of sooo many people :) The last thing you want to do is stall it or grind a gear because you are in a rush or something like that!!!! :P
Hmmm.... I was hoping more people with lightly moded cars would be running too though..... Believe me my car is far from fast.... I just want to give it a run so I know what time it can do... But I also dont want to be the slowest car of the night... how embarrising would that be... unless there was a prize for that too!!!
nah embarrsement is nuthin
everyone goes down to enjoy not tease who has slowest car!
it's just for fun i spose
but i just wanna take it down when i get bit more mods
coz stuff paying moeny everytime just coz ya wanna do a few runs!
get more mods and then go down
seems more of a better idea to me plus money wise saves me a bit! adrian :P
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
