  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yep you are Micko and god I wish those two would get a room.
Would save me wasting 1/2hr of my time reading thru the 10 pages of Drivel since this morning:D
You two ever heard of phone sex ??
Cheers
Ken
When you have finished having a bit of fun with Niz then pass her on . lol
atm all we are doing is trying to build one rex from a wreck .:bahaha: and prepare 3 others for the Forest Rally .
Have told all the regular clientele to come back after March 30th unless an emergency.
That should mean only 2 clutches a week.
Cheers
Ken
Originally posted by GTS-t VSPEC
Sounds like a tough job Ken. Do the rally cars use dog-boxes?
Micko, Any thoughts on Yanchep cruise?
See'ya:burnout:
One does , the rest use STI gearkits.
Cheers
Ken
