  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by caminperth
Lunch was great.. good to meet some of you.. well those that turned up anyhow..
Thought sitting between Dan and Lauren made me feel quite the little man.. hehehe :P
You thought you felt small.... I think I was probably the shortest person there.... and I'm not even that short!!!!! :P
Yeah Kym... Its always good to put faces to names... I am getting there slowly.... Each cruise or lunch I get to meet a few more people...
Strich9ine - came out pretty seedy didn't it.. hehehe... oh well.. I probably meant it that way subconciously anyhows.. :P
Niz - ahh - k.. Angel is the one who bought the front brace before I could get to it from PVA!!! Doh, would've given her shite about it.. :P
