  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha its ok my grandfather was a drunken gambeller that got my grandmother up the duff when she was 16 so yeah im not exactly that close to that part of my heritage. :D
No never learnt french wanted to do it in school but mum made me do japanese instead - friggin japanese eek!
Originally posted by Sneeza
its stuff you drink when your 16 hahha or if your poor and want to get maggo - cheaply hahah. Its not that bad actually, but it gets you rotten as
I did beam! drank 2/3rds bottle in one night ran out of coke so drinking it straight from bottle my mate drank 1/3 and was crooker than me. Held it down just wokeup like shite in the morning - never been able to touch the stuff again haha
haha - it was such a funny night that night i think it was the first time i got seriously blind.
Gotta disappear too im sorry - unfotunately i have to share the computer in this house bah humbug
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
