  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Wreck his car? Cool, I'll bring the axe:p
Rays workshop is airconditioned:p
See'ya:burnout:
Rays w/shop is only 100sqm , this is 280 sqm and evaporative sucks on a humid day.
Cheers
Ken
You and 1/2 of SAU WA going to help Adam 32 wreck his car
you wannah get in on it ken? hehe
i figured 5 no brainers should be able to do the job of a qualified mechanic:D
actually one guy is comin down who actually knows what hes doin, the rest of us are just gunah drink beers and have a bbq
There is no need to comply them, plus you can get away with more of the aftermarket gear they come with, so it's the route I would take. Planning on a full rebuild anyway.
See'ya:burnout:
Correct if you are willing to rebuild but people will expect a mint one.
Most 89's I have seen on the auction site sound well hammered.
Gotta remember in 89 they were a new novelty.
How many good 94 rexes ya seen ??
Cheers
Ken
I saw Wholagans car today, it has just been tuned, and they now have a dog-box with straight-cut gears. All they need is a decent driver:bahaha:
See'ya:burnout:
Jamie is actually a fair peddler though his dad could do with some smoothness lessons.
I think it would be a bit of an animal tho.
btw page ownage hehehe
Cheers
Ken
I thought that seeing as you posted 2 x posts over 3 forums that some one might have a clue by now.
Would love to help ( drink beer that is ) but have an R that is looking to go east ( I hope )
Cheers
Ken
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
