  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
emergency lane - havent used that one yet! U-turns are my speciality haha i used to have to drive mechanics to places to pick up cars in my last job haha they were really scared of my u- turns right in the middle of welshpool rd where theres 4 lanes - no problems haha. Never pranged a company car yet! Used to drive them practically fulltime and the only time i even dented one was when i reversed into the front of the car with my own about two weeks after i got my license.
Evening dudes and dudette ( singular cos Liz has gone but Niz is here )
pwptf , I may be old but can still show a few tricks.
Joe , If you can lick your dick , I will bring the vid and all the girlies you want.:bahaha:
Niz and Liz , love the womens perspective on love marriage and relationships.....
but will still never understand women:uh-huh:
Cheers
Ken
yeah saw that white one - it was pretty fine. You would never tell your was N/A though least its a couple of years younger than mine.
I hate toys in cars ive only got my p.piggy thats sits on my back shelf that can treally be see because of my xtra dark tinting anyway. It a nodding pig with wings and it had a gold chain around its neck that reminds me of p.diddy - thats how it got its nick - p.piggy the pimp piggy hehe
b4 you could tell due 2 the blue badges but they were stolen so i replaced em wit nismo badges from marlows bit ricey but i like it
yeah i hate cars with dashs filled wit toys a friend tried 2 put one of those shaking elvis toys on my window well let me just say they r no longer a friend! :P
but most of womens magazines just try to explain men so i doubt he'll find the inner workings of our mind in there - just how women guess the inner workings of the man brain or just how to get them around to our way of thinking thru bonking techniques :P
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
