  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Joe, if your success with the ladies is a reflection of the dance moves then count me out:bahaha:
Niz, I knew it didn't make sense, but I'm too nice to point it out:p
See'ya:burnout:
too nice !:D
Next will be chocolates and flowers , then a little Saturday Night Fever Joe style.
What woman could resist . She will be yours in ................
bout 100yrs.:D
Cheers
Ken
just cos u guys cant get it right - doesnt matter!! :D
but the guy didnt get my number thru me it was thru his sisters ex-boyfriend that i used to work with - does that make more sense? if it doesnt i give up!!
yeah apparenty you can tell how good a girl/guy will be in bed by the dance moves (guy told me this so far the theory works) soooo far with paul - im not missing out on anything haha maybe he is just a 60-second man haha
