  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeh well ive been speakin to another machanic mate whos now in london unfortuantely, he rebuilt mackas engine and hes askd me to check some things... turbo is fine which is good seeing as i just paid $350 fora new wheel and shaft. i just hope theres no bottom end damage then it should be an easy coupla hundred to fix at the head shop and back in action
with any luck ill be able to drive to your place on april 6!
