  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
Ohh btw , the plates I have from R34 will prolly be back on the market cos I decided that my plates I have are gonna stay.
And as I intend to be a 1 line family , they wont look too good on a Patrol.
Cheers
Ken
I didn't think JAFFEYFOOL would fit on a plate Ken
Patrol?
Originally posted by skyzerr33
doh u could of posted that like a week ago ken grrrrrrrr
pm me how much i can always sell mine to my brother
More than what I paid R34 for em.
Don't know if I wan't to sell em to someone who is gonna put Wookie on there car though.:):D :shake:
Cheers
Ken
thats why u keep selling them huh
I am drawing more people to the force.
* come to the 32R dark side.Once tasted you are mine , ALL MINE, BWAHAHAHA *
Sorry , got a bit excited.
Cheers
Ken
the dude in the red one that kept breaking out
and ken r well out of my price range
gonna do the fuel pump just ot be safe
Ahh but you don't know how much I paid for them tho. May be cheaper than you think ( but don't bet on it )
Cheers
Ken
Cheers
Ken
hey i've driven 3 now and still don't have one
but one would be nice as a 2nd car :) that or a chaser
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
