  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by 33Spec2
It was a vspec! (EVL_R33s)
Brett's car is way down on power atm cos he got a sad terb.
pulled quite low figures on Hendo's dyno.
But a set of 2530's and a power FC will change all that.:)
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken,
There can't seriously be that much difference, can there?
See'ya:burnout:
No theres not but the aesthetics are what does it for me.
Sort of like Kylie minogue versus Roseanne Barr.
Cheers
Ken
Jaffo???
Yeah i should b there on sun if thats ok! ill try and get some chicks 2 cum along!
Ahhh chicks
Things are looking up.
But don't forget that your mum in the passenger seat doesn't count
Cheers
Ken:D
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
