  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey Paul - reckon you can sweet talk old Ray for me...he has some R32 GTR ecu's in one of his boxes - I wanna see if I can get one that has been 'fixed' in the speed cut dept.
If I recall, a long time ago he said he would sell me an ecu for $100 - this was when I was having the knock sensor problems.
