  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hehe... I got this sent to me yesterday.... I though I would post it for a laugh.... see I told you I only post valuable contributions :P
My name came out to be Krusty Bubblesniffer :D
Post your names once you have worked them out too ;)
Children laugh 146 times a day, adults laugh only 4 times a day.....no wonder we're so unhappy... What's your new name???
Sometimes when you have a stressful day or week, you need some silliness to break up the day. Here is your weekly dose...
Follow the instructions to find your new name. The following is an excerpt from a children's book, "Captain Underpants and the Perilous Plot of Professor Poopypants" by Dave Pilkey. The evil Professor forces everyone to assume new names...
Use the third letter of your first name to determine your new first name:
a = poopsie
b = lumpy
c = buttercup
d = gidget
e = crusty
f = greasy
g = fluffy
h = cheeseball
i = chim-chim
j = stinky
k = flunky
l = boobie
m = pinky
n = zippy
o = goober
p = doofus
q = slimy
r = loopy
s = snotty
t = tulefel
u = dorkey
v = squeezit
w = oprah
x = skipper
y = dinky
z = zsa-zsa
Use the second letter of your last name to determine the first half of your new last name:
a = apple
b = toilet
c = giggle
d = burger
e = girdle
f = barf
g = lizard
h = waffle
i = cootie
j = monkey
k = potty
l = liver
m = banana
n = rhino
o = bubble
p = hamster
q = toad
r = gizzard
s = pizza
t = gerbil
u = chicken
v = pickle
w = chuckle
x = tofu
y = gorilla
z = stinker
Use the fourth letter of your last name to determine the second half of your new last name:
a = head
b = mouth
c = face
d = nose
e = tush
f = breath
g = pants
h = shorts
i = lips
j = honker
k = butt
l = brain
m = tushie
n = chunks
o = hiney
p = biscuits
q = toes
r = buns
s = fanny
t = sniffer
u = sprinkles
v = kisser
w = squirt
x = humperdinck
y = brains
z = juice
For example, George W. Bush's new name is Goober Chickenshorts, Tony Blair is Zippy Liverlips and Saddam Hussein is Gidget Chickenfanny!
Now when you SEND THIS ON ... use your new name as the subject. And
If you don't do this, then you are OLD, OLD, OLD and you don't want to have any fun.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
