  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
servers having a bit of a nervous breakdown today!
oh well drink enough paul and u may start to be interested in comic books & star wars yourself :P either that just go home early i guess. Trust me i'll swap ya i'll go out with the nerds and you can eat with my parents haha!
Originally posted by Boostzor
speaking of starwars im looking for a little movie called "Cops" i saw a while back. its liek a cops style take on storm troopers.
Know where i can find it?
do a search for troops
or go to the starwars site find the fan sites section and its in there somewhere
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
