  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
meh not my fault its the market ...the market dammit!!!!!
benn going down down down for 2 years but tis still only a paper loss if it goes back up he sweet only if he pulls out now will he actaully have lost the money.
well 5pm ppl i gotta go home and have dinner with my unlce and move the biggest goddam sofa through the smallest bendiest corridor ever.
