  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
helllllllllllllllllllllo dudes!
how r yas all! hanve't been on for a while, busy here and there!
what have i or haven't i missed? got a ten page assignment due tommorow and haven't even started it! ahhhhhhh anyone feel like employing a young un who feels liek quitin tafe coz he learns more at home?
adrian ;)
hehehee
sup 33spec2 i forgot ur name! ah i'm useless with names dammit!
hehe is it russel i forget hehehe anyways paul u know u want a work collegue! heheh! so hows the blissful romance tale
blossoming between u and niz?
hehehe jokes ;)
adrian :P
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
