Macka - I been once, 3 weeks after I got my car!!! On my last runs I started having the power probs I just fixed for the first time.
Don't reckon I got much out of the last session aside from the knowledge that I couldn't drive a greasy stick up a dog's you know what...
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
can't tell
the engine bay, can't isolate it seems to be plenum side but i can't tell for sure
Is it a new noise or just the fact that you are listening hard for the first time.
Cheers
Ken
oh yeah still no pressure at the radiator cap
Troy , stop being so paranoid and worrying about the worst case scenario.
As I said on the phone , it is probably the rad cap has lost pressure and allowing the water out of the overflow.
The murky colour is because you have probably boiled the water when it stopped and it's like giving the block a hot enema , all sorts of shit will come out.
Drive it home tonight , take it easy and don't use the aircond.
Get a new cap in the morning from Auto one , Marlows , Coventry's , whatever.
It's only a cap and the same as dozens of others.
Cheers
Ken
Cheers
Ken
fingers are crossed
driving like miss daisy all the way home and out to lumpy for the fuel pump
Ohh and drain the water , or get c red to do and stick some new coolant in.
The reason it boils is that without the cap pressure the water will boil at 100deg C
Your car should run normally at about 90 deg C and the 13 or 15 lb cap will raise the boiling point to about 120deg C.
this is why when you open the cap if it's in good nick after driving it , the water will suddenly boil , cos ya dropped the boiling point down to normal.
As yours has no pressure , it will boil easy.
Cheers
Ken
The hissing sound is probably normal pod filter induction or at the worst a vacuum line is off or split.
Just that you are looking and have suddenly heard what has been there all along.
Besides , a blown head gasket does not make a hissing noise , it causes the engine to run rough on startup ( as I said on the phone ) or blows water out of the radiator while it is running or a LOT of bubbles will appear ( some are normal )
Cheers
Ken
Originally posted by adam 32
when coolant says anti-boil - what does this actually raise the boiling point to?
it is the pressure in the radiator that stops most of the boiling.
Anti boil has an additive , like glycol or something , which raises the boiling point slightly , depending on the mix.
Cheers
ken
sounds good to me ken
i'll stop being a worry wart till the morning. :P
Good , can I close the online free mechanical w/shop and get back to whoring before pwpt60secf arrives ??:P
Cheers
Ken
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
