  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Try heptuple I think Ken, but it doesn't sound grammatically correct
Yea thats why I stopped at Sex ( hehehe ).
No desert , or are you just a fast eater , Hohohoho , on a roll.:P
Cheers
Ken
Oh really - bloody hell Ken you work too much - remember you're not getting any younger:p
Worked last Sunday at MC training day and this Sunday may be trying to get these damn rally cars ready for the Forest rally in Busselton on the March 28th w/end.
Cheers
Ken
