  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
skyzerrrrrr your headgasket has probably gne because of the excessive blowby from the busted ringlands
alas roll it into the shed.
Headgasket  from nissan is about $100
Macka , you are making about as much sense and at least as many spelling errors as Joe !:P
Cheers
Ken
ken ur a whore and u love it!
I like my avatar  and thats all that matters!
A double quote , thats a first .
I am not a whore cos they do it for money.
I do it for free:D
Cheers
Ken
Originally posted by Pva_Glue
Anyone needs experienced camera man? :P
You ?? !!
you spend all your time in the shotgun seat going
OMFG , I'M GONNA DIE !! OMFG .
and gripping the packshit bar ( grab handle ).:P :bahaha:
Cheers
Ken
and when would my ringlands busted and caused the blowby?
when do i ever make sence
dammit i keep getting phone calls and all of a sudden im a page behind
You paying them for phone sex or they paying you?
Page ownage , 2 in a row but alas .. no bookend.
Thanks for nothing Macka:D
Cheers
ken
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
