  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
I hope you aren't disappointed then, she's reasonably quick compared to a stock one now:D
See'ya:burnout:
And so is he .
But I am sure pwpt60secf can rise to the occasion and be a gentleman.
( not )
Cheers
Ken
Originally posted by Sneeza
The light at the end of the tunnel??? wow - thanks for the well wishes hahaha :P
My fiance and I still do so many things seperatley - like SAU and SES  for me- he plays alot of sport and stuff and also does speedcar... so we're not in each others face 24/7
Well THATS gonna change once your married.
Don't get me wrong , marriage is a fine institution and I do wish you well.
Just make damn sure it is exactly what you want and not bow to parental pressure like my sisters did.
Cheers
Ken
I am a gentleman, but i won't take it easy in the car, even when you wimper and cry:bahaha:
See'ya:burnout:
Err paul that was supposed to be easy ON the car , not IN the car.
Cheers
Ken
I knew I shouldn't have said anything on here!!!! Ken - trust me its all good! We both have the same goals and which don't involve kids, sitting on the couch or gardening hahaha
By the way you're all welcome to come to the cermony
2pm 29th March St Patricks church fremantle (adelaide st)
why thankyou , I'm flattered but will be in Nannup on the Rally.
* hmm thinks she prolly knew that. j/k *
The no kids is a good idea. Gives you time , money and ability to do what you want , when you want.
Cheers
Ken
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
