  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
I hope you aren't disappointed then, she's reasonably quick compared to a stock one now:D
See'ya:burnout:
And so is he .
But I am sure pwpt60secf can rise to the occasion and be a gentleman.
( not )
Cheers
Ken
Originally posted by Sneeza
The light at the end of the tunnel??? wow - thanks for the well wishes hahaha :P
My fiance and I still do so many things seperatley - like SAU and SES  for me- he plays alot of sport and stuff and also does speedcar... so we're not in each others face 24/7
Well THATS gonna change once your married.
Don't get me wrong , marriage is a fine institution and I do wish you well.
Just make damn sure it is exactly what you want and not bow to parental pressure like my sisters did.
Cheers
Ken
I am a gentleman, but i won't take it easy in the car, even when you wimper and cry:bahaha:
See'ya:burnout:
Err paul that was supposed to be easy ON the car , not IN the car.
Cheers
Ken
I knew I shouldn't have said anything on here!!!! Ken - trust me its all good! We both have the same goals and which don't involve kids, sitting on the couch or gardening hahaha
By the way you're all welcome to come to the cermony
2pm 29th March St Patricks church fremantle (adelaide st)
why thankyou , I'm flattered but will be in Nannup on the Rally.
* hmm thinks she prolly knew that. j/k *
The no kids is a good idea. Gives you time , money and ability to do what you want , when you want.
Cheers
Ken
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
