Originally posted by Nizmo
yeah probably was my change of profile - that was only done tonight - they say a change is as good as a holiday haha
Great , giving pwpt60secf the flick then and moving to better things ( like a one eyed 4ft hunchback ).hahaha
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no i think as petnames as paul gets is Niz haha!
hmmm hes actually going to a party - dont worry suspect he'll be home by 12pm - he'll get withdrawl symptoms plus i dont think hes party kinda social - but maybe im wrong haha. We shall see :P
If he went with Macka , he wont be home till dawn.
Don't know him but strikes me as a partay animal par excellenc'e
Cheers
Ken
no i saw paul put on a major sulk at sluggers - geez ive seen some top sulkers in my time - my ex being one of them but nothing like that - he's not the party animal. Macka is haha he cracks me up that boy, hes good value!
yeah if i wasnt taking joe i would probably start in scarborough but might as well go the whole way. Be going easy on the car tommorrow I think ive done enough damage.
You going Ken?
Doing the suckup thing tonight so will be gone in 1/2 hr.
Am hoping to go but maybe not all day.
Can't miss seeing the SAU babes can I ?:P
Cheers
Ken
Sluggers , you haven't actually been going out with him . Please say no.
Or was this the pool night ?
Cheers
Ken
who you sucking up to? the missus - what the inlaws over or something haha!
havent seen you in ages Ken - not since my first cruise anyway ;)
Nah , the missus.
If the inlaws were here I would be out cruising , walking , pulling out my nails with pliers , anything but being here.
Ahh does absence make the heart grow fonder .
Or have you a stack of please help questions like the rest ?:P j/k
Cheers
Ken
had a kebab!
hmmm guess wat house got completely destroyed on thurs by robbers while i was sleepin in my room - home alone woke up 2 hear the voices of 2 guys and started to panic phone rang and scared them off thank god everything in the house was turned upside down and 2 sets of car keys taken which they thought were 2 my car wrong!!!!!!
Originally posted by gtrken
Your right Russell , your boring.:P
Cheers
Ken
Come back Russ , I didn't mean it. Your not boring
* cough cough *
Cheers
Ken
sheesh , young people these days get offended so easy.;)
Originally posted by 33Spec2
had a kebab!
Shit , thats bad , who's keys.
Oh and I bookended . Yay! Troy will be impressed.
Cheers
Ken
um questions for guru ken - im sure i could come up with something haha nah i find igronance is bliss :P
Just thru a bit of a tanty because it wasnt his scene - wasnt most of us scene but everyone but him made the most of it - stood by himself and sulked. yeah i can throw some killer tanties but i think the boy is more high maintenance than me ;) *goes into hiding now from pauls wrath* haha
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
