yeah had 25GTT message me going to the casino tonight and if i wanted to go - but still a little sick and i went to all that trouble to clean and polish my car today i dont need it rained upon. But a night at the casino probably wouldve done me the world of good - oh well.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
multilevel carparks and my car do not mix!! the ramps scrape my kit - impossible to get up in a lowered car. Plus i dont like them anyway because i was locked in the stairwell of one when i was little so im a bit phobic of them.
Nah ive got an outside carpark when im in town i park in - the guy there knows me - everytime i go to pay he goes "so when am i going to see you racing this thing at kwinana" i get that question a lot!
Black is a bugger of a colour - got a few chips in mine i noticed today - couldnt think of any other standard colour i would prefer though.
haha sugardaddies noooo not my type - did have a young guy driving a ferrari ask for my number one day though - he was pretty hot too - bet it was daddies car tho.
yeah ive had a toblerone sooo yummy - one of the people my ex knew had access into the international room so we used to go in there - it was as boring as all hell but all your drinks and ****tails were free haha its all u can drink :D
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
