  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
yes my mum is the same - i would be the same if my car didnt take every cent i owned! oh well least the pleasure lasts longer with the car - your arse has to get pretty damn big before the car no longer fits :D
Bwahahahaha.
Will be a looooong time then Niz :shake:
Cheers
Ken
Originally posted by Pva_Glue
ohh quick reply worxs :D
anyway Good evening all :D
Joe that sig photo is soooo cheesing me off and must really slow the page load down for the 56k users.
Oh and hello and why haven't you locked some of the threads yet ?
Cheers
Ken
so you coming for full day ken or does your get out of jail free card have an expiry date :D
Every thing has an expiry date and mine is bout 3pm .
Did you say your bringing snags for us snags? lol
Cheers
Ken
Originally posted by Micko
Hi all.
Hope you haven't been drinking Niz - got a big day tomorrow.
Hope the bloody weather holds out for us...
No she hasen't ( I've been watching ) but mores the point ,
have you ohh * one more beer in the fridge * Micko.
Cheers
Ken
Good work Nizmo.
Ken - you gonna make it tomorrow?
Go back bout 8 pages and see the unfolding saga of
1 paying attention
2 sucking up
3 doing what is reqd
4 obtaining leave pass
5 trying to extend leave pass
6 almost courtmartialled and losing leave pass.
Yes I will be there and Niz iz cooking my lunch ( only she doesn't know it yet )
Cheers
Ken
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
