  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe it wasnt a servo it was where the service dept of new town toyota where i used to work - which even worse - they know me :D But i had a couple people say they were really worried it was coming from there car til they saw it was mine - so least im not the only person that starts getting anxious at the smell.
haha just before the R34 went up in smoke joe goes to me "do you smell burning tyres" im like "who cares as long as its not frommy car" then black smoke starts pouring out the car in front oops.
Originally posted by GTS-t VSPEC
Niz, Ever heard of a car jack?:bahaha:
I got page ownage Troy:p
See'ya:burnout:
considering a friends of mine broke while he was under the car and nearly killed himself - im not going there! but if you want to have a go - be my guest :D
i just hate anyone thats in my way :D Apparently you get road rage as much as i do paul - say sneeza anyway - ask joe i curse n swear and talk other drivers thru the process of driving...... haha i think i seriously intimadated a learner driver, after a while she got the hint and pulled off the road haha poor thing.
Good luck with the interview russ - whats the job?
haha my mum does the hand gestures - i learnt from the best road rage instructor in town.
Yes well i was getting to the yelling point - probably wouldve (specially at stoopid toyota echo doing 50 in 80zone pffpt) but joe was in the car and i didnt want him thinking i was a raving maniac.
Originally posted by 33Spec2
Shell servo will b my second job mite try 4 three jobs!
hahahaha sneezas impersonation of paul - 50k per hour 40k per hour! OMIFUC*INGGOD 40k PER HOUR!!!
^ funny cos it was what i wa saying to echo "We are doing 50 didnt say 80 back there WE ARE DOING ***ING 50!! wish this arsehole would get out the way - does he even know where the F-ing accelator is - wanker" haha
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
