  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeh but i got no gtr here im not pulling over 400rwhp....sorry fwhp (dammit!!!!) i think heat is the only concern. if any1 has ever smoked the whack tabacy b4 they know its not hard to get a good seal witha hose in a coke bttl :D
What hick special edition? something i should know?
I think hes at Uni. He broke his phone on Fri last week and hes all bitching and moaning about how the pnansonic is soo great and the nokia is so crap. So to demonstrate this point hes throwing the nokia at the floor and it breaks too. now he has no phone not even his "crappy" backup nokia
*runs for the turn sigs off switch!*
Subject: [wa_rally] (unknown)
You know you own a Street Machine when:
The emissions test guys start laughing as soon as you pull into the
bay
You can't drive your car in the rain
You can't drive your car in the sun
Your missus is afraid to drive your car
You are afraid to drive your car
You spend more on tyres than on food
Your council decides not to re-pave your street with that new
rubberised asphalt becuase you've already "done such a good job of it"
You spend more on car insurance than house payments
Your insurance company has to create a whole new acturial table to
cover your and your vehicle
You have never argued with your wife over making the mortgage payment
or buyi! ng that new set of headers while they're still on sale
You see a picture of your car taped to the bulletin board at your
local police station
Your local council has passed an ordinance making it illegal for you
to even enter a school zone unless you are on foot
Traffic advisories are issued whenever your car is spotted during
peak hour
Your mechanic names his new second shop after you
You have speed shops on your telephone speed-dial
You're tempted to wear your fire-suit just to drive to work
You refer to the intersection at the end of your street as Turn 1
You get pulled over for doing 120 in a 60 but the cops will let you
go if they can look under the bonnet
News footage of cops chasing you is used as a training video for the
highway patrol
Your face looks like you are riding a NASA centrifuge when you drive
the car
You need parachute braking
There is no possible way t! o "sneak-out" of your neighbourhood at 6am
Your pets scramble for their hiding spots as soon as the garage door
is opened
You wear earplugs in your cars
You find out that stock side mirrors vibrate at ordinary highway
speeds - more than 240 km/h
The exhuast pipe has a larger diameter than the tailshaft
Your fuel pump can be used to water a golf course
Your engine idles at 2800RPM
You aspire to crack 8 mpg one day
The airport on the other side of town complains about the noise
coming from your garage on Saturdays
The fire brigade has showed up at your house because alarmed
neighbours reported smoke billowing from your garage
cheers
Neil
and to top nizmos sig -
"You know the world has gone crazy
when the best rapper in the world is a white guy,
the best golfer in the world is a black guy,
France is accusing the US of arrogance and
Germany doesn't want to go to war."
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
