  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
well shes got a whip, handcuffs and a silk scarfe will that do?
Ohh I am SOOOOO there!!:D
Troy , you got somewhere I can send a 1.3mb vid for pwpt60secf.
Kym's email wont take it either.
Cheers
Ken
Originally posted by adam 32
you sent me like 50?! even the one of joe with the black g-string bent over the bonnet of your car, dont know what inspired that one
I hope that was photoshopped .
Please say it was photoshopped:D
Ewww , too much for the imagination.
Cheers
Ken
Originally posted by Pva_Glue
I can I want Please!
[email protected]
cheers KEN!
Joe , normal email stops at 1.1 mb.
Sides , I would have to clear it with Paul.
Lets just say the speed was err...... yea.
Cheers
Ken
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
