  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
cam - his ITC is sorted? damn if he couldnt get it sorted it was mine!! could you have pulled a few wires out and put your hopeless look on for me - "hmmm this looks hopeless better give it to lauren" kinda thing. cmon u scratch my back i'll lick um er sorry scratch yours.
thats easy talk him into powerfc and then u can have the itc and the safc
well my ex was a bit of a smoothy but my parents could see right threw it - funny thing was first day my ex met my dad - my dad was really buff just finished doing weights and had tight t-shirt on - had this real mess with my daughter and i will kill you look haha :( i love my dad he's a sweetie puts up with a lot of crap fromus girls.
that was the plan - now cam will have to live with the fact i will enver get my ITC etc!! :(
