  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
me and my friend spooked a mate of ours out once - pretending we were from some cult looking to recruit him thru emails etc - spooked him cos our little cult knew so much about him and he hadnt a clue who it was - nearly 2 years later we finally told him - shouldve seen the look on his face. ahhh high school pranks.
Anyway report it but i really think serious thieves n murderers would not mess around with notes!
good point ill just hav 2 wait and c wat happens!
it wouldnt b paul he knows it a n/a!:(
Hmmm , Mackas chasing some panels and pwpt60secf said he was gonna supply .;)
Just joking , I would never accuse anyone but if I found out someone did , would not waste my time calling the cops
*We have ways to make you sorry*
Cheers
Ken
Originally posted by skyzerr33
yeah ken does a strip o gram for u
hahaha classic troy. instead of verbally beating them to a pulp next time i'll just let ken take over. :(
almost my bed time to fellas ;)
No was thinking more of locking them in the back seat after Macka has had another boozy night combined with a particularly nasty vindaloo curry
Cheers
I have gasmask
Ken
Yep , think I will join you.
Going to bed that is.
I mean I will be going to bed and so will you... in separate beds... not at the same address... ohh never mind.
Goodnight all
Cheers
Ken
haha ken. unfortunately i take up 25% of my double bed my cat takes up the other 75%!! Shes got a big arse and if you accidently kick her she latches onto your leg - ouch!
Hmmm , I dont mind an active ***** . Hehehe
Cheers
Ken
micko pops in again for a goodnight call
hey micko can tandi refund money via an eftpos machine?
cause kylie got the wrong modem to start with went back got the right one which was $20 cheap and they refunded via the eftpos machine
didn't think u could do that
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
