cars are about the only thing that can hold my attention long enough and that pays shite - so i would rather do something boring but have the money ot be able to do my own car up eventually.
problem is i dont know what i want to do
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahhah mid life crisis I mean 1/4 life chrisis...
Just find young attractive Loaded guy and get married!
Niz,
It's difficult to find something you enjoy, even I don't get excited about work, it's OK but not great. I can do lots of things, but the only stuff I really enjoy is mucking around with cars, but I ain't good enough at that.
One day I will own a car tuning shop, but till then I'll keep working my normal job.
See'ya:burnout:
yeah i'll go on a world trip just after my 21st - should have my investment house by then too.
:P
Rich guys are usually egotistical pricks i cant stand an ego! my ex had the biggest on earth and it used to shit me
Originally posted by GTS-t VSPEC
I'm going to the UK, haven't had a holiday in ages:D
See'ya:burnout:
meh ive been in my job for almost 2 1/2 years and i dont get sick days or holidays or ne of that crap.
it sux 4ss!!!!!!!
oh btw. i can move my leg again now. still hurts to stand on and i still have to use the crutches but its getting a bit better
YAY FOR ME!!!!
Psiker
Meh being rich aint all its cracked up to be. IMHO if i got enuff to get by and have a few little luxuries im right. Rich is nice house nice car and good life. It dont have to be a porsche and a mansion. As long as i can get stuff i want without too much saving its all good
all the people i know are poor and i tend to end up goin out wif ppl just as poor as me. (read a whole 2 ppl) but i dont think it matters how much money u have. if u can get thru a week of living on 15 bucks with ur partner with no food in the cupboard u can get thru nething. being poor realy tests the strengths of ppls relationships i believe
Psiker
:D
*Joe take big breath* No offence Nizzy
come on Niz! Wake up! Not all are like that! I understand you do have problem with egomaiacs but that's bit stereo typic judgement on people isnt it? you have to learn to let it go.
I know I wont be the last person you will listen to but I think Judgeing people of their social statues as well as their physical apperances... this goes to all of you reading this :P.
the best life lesson I've learn so far is that you are not alone in this world, you have to make effort to get along with others :)
does that make sense? :confused:
*Joe crawls back to hole*
cheers
Joe
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
