  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
well glad to hear you are not.
egos? everyone have it but it's depends on who & where you uses them differenciate people's personality.
I have to say that I have bad thing when I judge people at 1st impression.
if I get bad impression from meeting someone for 1st time I wont even talk to them for rest of my life... visa versa.
I am 1st impression man, I always will be. bit stubbon but hey that's me.
Try hard rich people? hhmm that;s intersting concept. dont know anyone like that.... :P
I know I am not rich at all now... but I am looking forward when I make my own 1st million :D
cheers
JOe
Defination "try hard rich people": people that dont actually have any money but pretend they do - usually have very high opinions of themselves, hang out in all the trendy places, everything is about how they appear to others - just very fake people.
I think i just cant stand it because i had an overdose of it in the car industry and also with my ex - fake people just shit me like nothing else!
haha yeah just screams tryhard - i had some guy fitting the discription pull up next me while i was walking along the road in a soarer yesterday giving me the full lookover and he had slick back hair and the gold chains - errr yeah right! Know theres a reason why i dont like soarers - just look at the drivers haha
me back....
damn contractors.. actually no - damn peepholes in the front door.. i swear the bloke was inside and just wouldn't open the door!! hehehe...
oh well - got to drive my car around and get paid for it.. :P
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
