  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey - I wrote the 180 off tonight. NOT MY FAULT! I was trapped in the car - my feet were jammed in cause the engine was sitting on them. Snapped the drivers side wheel off. Got a nice gash in my neck - should look wicked for the wedding! :D
Happenned on fremantly brd /albany hwy intersection.
I haven't stopped crying for like 3 hours
MY GOD !!
Is this a sick joke.
What are you doing here when you have just had a trauma like that ?
Cheers
Ken
All the people at the Gosnells pub said I was up on two wheel and they were all congratulating me on my driving hahaha... well its not really funny. A car turned right - across in front my me (like a t-bone type thing) I launched off his bonnet when on two wheels, went through 4 traffic poles then hit the last one and landed on the side. Then the car fell down. I was just screaming to get me out of the car.. I thought I would be stuck there forever hahaha
no - this is real. I don't know.... I needed to chill out in here. I've been in the hospital already - dosed up nicely now
Ahh shit !
That is real bad news.
Big *hug * from me and glad to hear your sort of alright.
We don't need to lose any spunky SAU female members .:D
That will make for an interesting wedding speech
Cheers
Ken
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
