nah i think the prob is the rubber stops havent been replaced - once i get those done and the wheels are aligned and balanced if that doesnt fix it i will look into what else can be done. I acknowledge that lowered cars are bouncy but its nothing like when i first got the car - if i can get it back to that standard a happy girl i will be ;)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
mornin adrian..
the ITC we're talking about is the Apexi one.. the Apexi AFC does the same thing - looks way funky but I can't find anywhere to mount them for the flashy light effect.. hehe...
ride is gooooood ;)
is it pretty much standard - i aint hightening it anymore than a few mm's. The stops do make a difference - just where to get them from - i thought cred would of thought to replace them when they did my suspension!
Originally posted by caminperth
mornin adrian..
ride is gooooood ;)
I put mine in the glove box under my SAFC.... get brett to whack it there aswell perhaps? the further away frorm drunk peoples fingers the BETTER!!
niz my mate had them rubber stops in his subaru and they are prone to popping out, coz one of his did so one side of his car was lower then the other it looked wierd! i had a good laugh though! they called spring stoppers aren't they?
cool cool cam ITC sounds boss and i presume when you say AFC you talking bout the old skool 5 knob apexi one?
adrian ;)
yeah they are prone to breaking and wear n tear etc - but i swear they make a difference - well i guess i'll know for shore once i get new ones in to see if that fixes part of the problem. I think that may be the reason my cars front end has decided to sink a bit too ;) I could be way off the mark - but these are my theories.
yeah spring stoppers to help heaps! i was just mentioning how they do pop out maybe your front ones have popped out? if you have some in there already!
yall reckon i should ditch my apexi n1 front pipe and get a 3 inch dump/front made up or just get a dump made up and bolt onto front pipe?
adrian ;)
25GTT - I have a large fist that says "drunk ppl no play with stuff in car" ;)
Adrian - yea.. the old skool ones.. work ok.. the car came with them so they'll do till I decide to upgrade the whole computer..
Niz - pity c-red didn't think to do that, or tell u they may need to do that.. some things don't change maybe? found out mine are std coils and shocks.. my coils have been heated so have thought about changing them, wheels world quoted round $500 for a set of whitelines that would sit the car about 30mm lower.. but with the shocks being nearly 100,000km old i think i'll just hang out and get some cool coilovers.. :D
yeah i wouldve liked coilovers - out of price range tho.
I was actually told by another mechanic exactly what had to be done to my car in great detail - including replacing the stops and stuff. just annoys me these things dont picked up - i mean you've got the car there u might as well do this - makes you extra money while your at it. I shouldve asked but the thing is all the other suspension shops were going to do it as a package so i just thought cred were going to do it as well - cant complain about the price but i wouldve preferred to pay a bit more and get the whole lot done and outta the way. but anyway nbot everything goes to plan.
he was the one i talked to in the first place - its my fault i shouldve asked i know not everyones a mind reader but its just the suspension places did as part of package assumed he would too - its good when i worked in welshpool and it was close to drop my car in but now its too far away to keep going back and getting stuff done - prefer somewherein osb park.
Adrian - why not just get a dump pipe to suit the apexi one? be alot cheaper right?
coilovers are cool.. ;) adjustable stuff is fun... but yea - probably wouldn't waste the $$ on it...
Niz - maybe u should chase jash about it.. he's been pushing to get customers - this could be a good test?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
