god no! shorter than 6'4!
Paul thats not such a bad thing from my point of view :P
macka avatar down because its a little too inappropriate for work if i get caught whoring which i often do - so its a weekend thing
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nice one niz... thanks for the effort - but it's pretty hard to imagine something like that to entertain me when there's a big fat hairy smelly bloke sitting in the cubicle next to me who had waaaay too much garlic for lunch!! hehe...
Originally posted by GTS-t VSPEC
By giving out all your details, I thought a woman never told stuff like that.
umm.. that makes no sense..
By giving out all ur details, [conequences here]
not what u wrote.. anyway..
