  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
Ok i have something to say....
Girls who think that G's are uncomfortable are just being selfish and arent thinking about us guys!!!
2ndly I hate it when they pull there jeans up and we cant see the G :P
DAMN RIGHT..
think about us guys..
but seriously.. how sexy is it yea?
when u can see it?
macka/paul - am chasing an exhaust cam pulley.. after talking with 25GTT i'm conviced that i must have one! combine that with the fact that i'm getting my timing belt done very soon anyway means i may as well do it while the belt is off..
nengun says $185 for the pulley on their website, but brent sent me an email describing both inlet and exhaust for $428?? I assume that postage is about $50. They quoted delivery of one week..
I asked for pricing on the Trust one's shown one the site but haven't heard back yet..
macka/paul
saturday some time i need to go back to the headshop and re-seat the valves then bolt it back together. the guy was too busy today to do it. however being a saturday he aint guah wonah work later than 3-4pm and itll take 2 hrs. so as long as i can get to the head shop by 1-2pm itll be sweet but if we aint gunah get back on saturday by later hat afternoon i cant come down south. i want my car working again
tristans comin over on sunday so anyone whos available at any time the help would be greatly appreciated. im not goin to autosalon.
paul - check ur pm...
macka - am going to have the timing belt of anyhows so thought why not put one on.. so far have afc, itc and more boost.. am going to get dump pipe and fmic - basically very close to the setup 25GTT has.. he seemed to think that the pulley gave him a decent increase in power right over the rev range - so for a couple of hundred bucks I thought I'd give it a try...
cheap power if it works.. :P
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
