paul - thanks mate, just got ur pm.. the car is going in for surgery while i go to sort my life with my other half out in malaysia over east/anzac day.. so i'll need to get hold of the pulley before good friday..
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha you may need wide angle lens but i have more leg than any of those girls hehe combine my legs with kyles bust and we would win for sure :P
Im good thanks dark back to my bored self after all the rush!
Cam it wont help big time unless your running Cams and A big arse turbo with light flywheel all killing midrange then u put the cam gear
LOL if i wanted 8kw id take my centrifical fan off and put an electrical fan on....
Anyway keep us posted of results the guys prove me wrong all the time
seeya boys and girls im off home :P
paul - not worried bout macka.. :P it ain't that money is no object - but $200 is bugger all...
as for tuning it myself - i sense an imminent explosion if i start messing with valve timing.. much more to learn before then i have.. hmmm..
    • Would be easier to just run the RB25DET gearbox, all you would need to do is have the tail shaft / prop shaft shortened. S15 uses the rear ABS diff sensor for the dash speedo, so you can skip using the gearbox speed sensor.
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
