  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I'm pretty sure no one is liable because it was never released here. Only ever came out in Japan as a magazine cover DVD. Its the same reason why they can show anime at JAFWA, no one in Australia owns the rights to distribute so its pretty much free to watch and distribute, as long as its non-profit.
Dude, if Skyzer can talk about engine manuals in nods and winks, then this should be ok. Thats far more illegal than an option svcd cause companies in Perth actually sell the manual.
I'll give my left nut if Option care about a drift fan in the west of Australia making copies of their vid for other drift fans.
Go on then. You'll just be putting more coin in Tel$tras pocket :P
Its not like Best Motoring, which a company in Singapore makes english translations for and Autospeed sells on their shop. Option is only released in Japan, Japanese language only and no distributers in Australia.
