  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
The sony players aren't too bad, not 'A' grade, but then they aren't 'A' priced.
The same mpeg boards are found in the cheap ass DVD players. There is a singer unit (in the cheap ass range) that is probably the best of a dodgy bunch (rick heart has them last I checked).
rev210, things would get a hell of a lot better if the americans would recognize true black to be 0IRE instead of whatever the hell they think it is (7.5 issit?).
adam 32, you enjoy playing region 1 discs on your Sony? I don't think I've heard of a region free model by them. Ever. And mods are expensive too. I'm not a Sony head so don't hang me it their latest stuff can do it :)
evening all..
got zanda's turbo off.. found the problem with the turbo/manifold gasket.. it's missing one of the 4 nuts holding the turbo on!! not quite sure how it would've come off cause there's a tab washer there stopping it? also the other 3 nuts were like finger tight?
wierd!
Originally posted by Pva_Glue
I just had crazy thought when I red your reply...
Why Oh Why can't I do that with WOMEN :):D :bahaha:
smart arse.
Because we pick you - you dont pick us :) We have the power well thats what you learn when you watch the discovery channel -
thats why males are programmed to bonk almost anything while females are a little fussier who they mix their gene pool with.
Wish troy was here - he usually a wealth of info on this stuff :)
Originally posted by macka
rev  u dont need it chipped to play dvds? do u?
The PS2 plays DVD's just not multi region without a mod chip. Put the chip in and you can play multizone (read pirate) games too.
The mod chip for the PS2 is not very expensive.
The PS2 enables you to play GT3 and race mines GTR's around.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
